F-20 ground speeds
Mike
06-07-2003 14:07:26
Cam anyone tell me how fast my f-20 would run with 14.9-38's on it in low gear? We have a 3.75 mph speed limit in our club and I'm not sure if I can be close to that. Would like to be able to run full throtle in first or second. Any imput would be helpfull. Thanks
Donnie
06-10-2003 08:59:09
 Re: F-20 ground speeds in reply to Mike, 06-07-2003 14:07:26
If the tractor has the road gear in it, the gears will be fast all the way threw. The F-20's with out road gear are slower threw the gears. With 14*9*38 with road gear, and 10% rpm added will run close to 4 mph.
Wheels
06-08-2003 20:27:49
I can't give you the numbers but my brother has an f-20 with 14.9x26 tires that he pulled once last year. They said he was at 3.8 mph in low gear. I am afraid you might be too fast although the operators manual lists the speeds a lot slower than My brother goes. This is a stock tractor as far as we know. Its definitly not turned up that much.
Wheels
FB
06-08-2003 11:18:19
should be able to pull second wide open, we can with a 39 farmall M, should be pretty close gear ratios
