MARION FAIR (MICHIGAN)TRACTOR PULL JUNE 16TH
2 cylinder
06-07-2003 14:12:51
Farm stock classes (past years 2750# through 7500#), pull starts at 5pm on Monday June 16th.
TeeJay
06-11-2003 18:15:26
 Re: MARION FAIR (MICHIGAN)TRACTOR PULL JUNE 16TH in reply to 2 cylinder, 06-07-2003 14:12:51
Exactly where is this pull held, whose sled is being used and whose rules?
Thanks
TeeJay
2 cylinder
06-12-2003 06:50:15
 Re: Re: MARION FAIR (MICHIGAN)TRACTOR PULL JUNE 16 in reply to TeeJay, 06-11-2003 18:15:26
The pull is at the Marion Fair Grounds in Marion which is on M-66. As for your other questions I'm not sure, here are some phone numbers for questions, Jim Ryan 231-743-6363 or Fair Office at 231-743-6451. Hope this helps
JD puller
06-08-2003 18:10:07
do you have some rules that you can email me? hp pull/or speed limit? pay?? stone boat?? thanks.
2 cylinder
06-09-2003 07:16:35
 Re: Re: MARION FAIR (MICHIGAN)TRACTOR PULL JUNE 16 in reply to JD puller, 06-08-2003 18:10:07
It is a transfer sled pull, with 5 mph speed limit (which in past years is not inforced) no RPM limit, any gear, any tire size, hitch 20" high and 18" back and no bracing of the hitch. The pay out will probably depend on the state funding, but in the past it was less than $100 to win. The rules may change but this is the rules from past years. They usually draw a lot of tractors from the Central Michigan area!
JD PULLER
06-09-2003 15:32:08
 Re: Re: Re: MARION FAIR (MICHIGAN)TRACTOR PULL JUN in reply to 2 cylinder, 06-09-2003 07:16:35
the class's now 3000,4000,5000,6000,7000
