To much compression?
Kurt
06-08-2003 16:48:42
I've got an Allis WD and my piston is 1/4" away from the head and it get over 300 lbs. of compression. I went to my first pull and as soon as it started to lug it just fell on its face. I put the tractor iin 2nd gear and and I can make it stall out using my brakes, where last year when I was using 175 pistons it was unstopable with brakes. What do you gys think?
Jason
06-09-2003 02:43:20
 Re: To much compression? in reply to Kurt, 06-08-2003 16:48:42
Your not too high if you can use racing fuel with
about a 105 to 110 octane rating. Should make good
power. I run just under 300 psi with no problems.
Kurt
06-09-2003 11:19:59
 Re: Re: To much compression? in reply to Jason, 06-09-2003 02:43:20
I run cam2 fuel which is 110 octane.
a puller
06-09-2003 19:26:07
 Re: Re: Re: To much compression? in reply to Kurt, 06-09-2003 11:19:59
I always went on JD's nothing over 200
phil
06-08-2003 17:02:12
The compression must be 10 or 11 to 1, it must really turn out some HP. It should lug as well as before if the octane & the timing match the compression. Remember, you still have the same piston surface area as before - the main thing that you must do to get torque is to slow the flame propogation. Try the highest octane gas that you can find.
your too high
06-08-2003 18:06:42
 Re: Re: To much compression? in reply to phil, 06-08-2003 17:02:12
