966 and 1066 IH
KB
08-02-2001 11:55:27
I know this is an antique forum but thought some of you may know the answer to this question anyway. What is the difference between the engines in a 966 and a 1066 IH, and are they easily interchangeable?
Robbie
11-05-2002 18:17:56
 Re: 966 and 1066 IH in reply to KB, 08-02-2001 11:55:27
The only difference I know of is that the 966 came out of the factory non-turbo and the 1066 came out of the factory with a turbo, and the manifold on the 1066 slightly different because of the factory turbo.
1066 man
08-04-2001 08:45:11
The 1066 has the same motor size as the the 966, but the 1066 has more horse power than the 966. COMMON SENSE!!! The bigger the number the bigger the tractor!!!
Greg H.
08-03-2001 08:25:38
Baystatebinder is right the turbo is the only difference. Well there is also a small difference in the hood as the turbo makes the hole possition different where the exhaust pipe comes through. Other than that I can't think of any difference. Later, Greg H.
Justin
08-04-2001 05:56:23
 Re: Re: 966 and 1066 IH in reply to Greg H., 08-03-2001 08:25:38
Didn't the 966 have the high flow head because it didn't have a turbo? Seems like I've heard that somewhere.
Justin
One more thing
08-03-2001 09:40:51
The name plate. One is 966, the other is 1066
baystatebinder
08-02-2001 13:58:51
They are exactly the same 414 cu inch. The 1066 has a turbo and the fuel pump puts out more fuel I think the pump is the same. They both turn 2600 rpm.
the tractor vet
08-05-2001 19:07:48
 Re: Re: 966 and 1066 IH in reply to baystatebinder, 08-02-2001 13:58:51
The differance is in the head and the pistons are differnt and the pump settings are differnt also a 966 uses a 12 inch flywheel and a 1066 uses a 14 inch flywheel and clutch. There are other small things .
IHBRAD
08-06-2001 06:57:29
 Re: Re: Re: 966 and 1066 IH in reply to the tractor vet, 08-05-2001 19:07:48
One piece of information you might want to be prepared for if your putting a 1066 stock turbo on your 966 is, a 1066 has a little bit different fuel tank configuration to make room for the turbo
pcy
08-12-2001 09:00:44
 Re: Re: Re: Re: 966 and 1066 IH in reply to IHBRAD, 08-06-2001 06:57:29
the compression ratio is higher on the na motor, the turboed motor has oil sprays that spray oil into the bottom of the piston, and the oil pump is wider on the 1066 motor, the early 815 combine with the 414 and the early 966 head did not have valve seats, all the heads weather 426 427 0r 888 part no have the same size valves, hope this helps
