900 Case
BOB
06-15-2003 21:22:43
Is there a hub that will work on the frount axle to let you run a stamped rim instead of the big cast hub.
Jim M
06-20-2003 02:56:06
 Re: 900 Case in reply to BOB , 06-15-2003 21:22:43
My dad used a 8-hole hub off of a late 6 speed 930 on his 900. On his 930 that was done first he used some 6 hole hubs off of a 730. The bearings were no problem but you may have to have a sleeve made to press in the hub to get a seal to work. He is using 7.5L 15 tires on both. The 8 hole 15" rims were at little hard to find but Hey Machinery Co. at 785-594-3441 had them.
