Anyone every got a wd nf under 3500
Andrew
06-17-2003 18:31:34
has anyone ever got wd nf under to get into the 3500 pd class. and if i could were the best spot to put weights on
Alllis Puller
06-18-2003 17:30:42
 Re: anyone every got a wd nf under 3500 in reply to Andrew, 06-17-2003 18:31:34
I run in 3500# and make 3400# with me on it, I weigh 180#. I stripped the pto, the lift arms and cylinders to make it. I've went down as far as 3200# with my pressed steel rims and 16.9 tires and no fenders. If your going to stip it put all the weight on the back. I've pulled on power tracks and in that class very rarely does the front end come up. Your defeating the purpose of stripping it if you put all the weight on the front.
Scott
06-18-2003 11:17:25
No problem. WD will go under 3500 easily, and a WC will get under 3000 with a little work.
Jim (Mi)
06-18-2003 07:58:56
No problem. I have mine right at 3500. I took off the hydraulic rams, and most of the 3pt hitch. I have a conversion kit, and actually left a lot of it on so I could utilize the drawbar. If I stripped it entirely, I could lose an additional 2-300 lbs. Make sure your tires are unloaded. I even still use the heavy POW rims, and make it. You could really underweight the 3500 class. Strip off the hyd pump, and entire PTO and snap coup, or 3 pt, and make a home made one. And also keep the gas tank low. :>)
FB
06-18-2003 10:24:34
 Re: Re: anyone every got a wd nf under 3500 in reply to Jim (Mi), 06-18-2003 07:58:56
i would say put what little weight you'll have to move on the front, we are pullin our M in 4500 and put it all on the front
Jim (Mi)
06-18-2003 12:24:28
 Re: Re: Re: anyone every got a wd nf under 3500 in reply to FB, 06-18-2003 10:24:34
At the last pull with my set-up I came in 5 pounds light. I need to take a little more off so I can weight up in the 3500.
