Another ? on wd in 3500#
Andrew
06-19-2003 16:28:24
with me on my wd it weighs 3540 with me on it i weight 220 pds. I ave everything off imaginable pto and hanger the hydro ram brackets and rams are off the fenders and brakets are off along with the 2-point hitch thing thats goes threw the carry all plate and she still overweight. Could this mean i have fluid in my tires. i have the light rims on too. And it only has a little over a 1/8 tank of gas. thanks help please.
kendall
06-24-2003 14:58:56
 Re: another ? on wd in 3500# in reply to Andrew, 06-19-2003 16:28:24
Early wd's had a lightweight hollow narrow front end. Check that you don't have solid cast front that weighs almost twice as much.
allisman
06-22-2003 16:05:39
if you have a narrow front end take off one wheel,also after starting the engine you can remove the battery, but don't kill it or your done. good luck.
Allis Puller
06-22-2003 18:36:58
 Re: Re: another ? on wd in 3500# in reply to allisman, 06-22-2003 16:05:39
You can take off the battery only if your running a magneto, But that tractor has to have fluid in the tires with every thing you've stripped. Did you take off the fenders? Those weigh quite a bit.
Jerry
06-20-2003 19:11:16
Most of the pull's allow 1% over. I doubt if anyone would argue over 5 lbs.
MAC
06-20-2003 15:44:53
AL
06-20-2003 11:04:50
Put in a smaller battery, and ditch the oil bath air cleaner..also ditch the hydraulic pump since you took off the rams anyway...Al
Jim (Mi)
06-20-2003 08:29:31
Sounds to me like you definately have fluid in em. Maybe not a full load, but some kind of residue still in there.
donkster
06-19-2003 17:27:49
roll the tire valve down and pop it and see.
