First time pulling a 806D need help on what gears?????????
jeremy
08-05-2001 15:10:10
We have a county fair going on this week and I'm taking my dad's 806D I was wondering on what gear would be the best??? It is stock and its not turned up at all. I was also wonder if any one nows how much does a 806D weight????? Would it be in the 10,000lbs or 12,000lbs class????? Any help would be great. Thanks jeremy
jeremy
08-06-2001 11:59:18
 Re: First time pulling a 806D need help on what gears????????? in reply to jeremy, 08-05-2001 15:10:10
thanks you guys for the info I did weight it and it is 11,700lbs but going to try some how to get it down to 10,000 before thursday.I really do thank you guys for your help I'll let you guys now how I did on friday.Thanks jeremy
Jordan
08-07-2001 06:30:52
 Re: Re: First time pulling a 806D need help on what gears????????? in reply to jeremy, 08-06-2001 11:59:18
Are you by any chance talking about the Mercer Co. Ohio fair? We are also having a pull Thurs.
jeremy
08-07-2001 14:27:09
 Re: Re: Re: First time pulling a 806D need help on what gears????????? in reply to Jordan, 08-07-2001 06:30:52
No jordan sorry I'm not.I'm going to the boone county fair in Illinois
Greg H.
08-06-2001 08:37:44
Jeremy, That's a good tractor, but if it's a weight transfer sled I'd use 3rd on the low side, and prepair early on to use or torque. My brother in law who uses a 966 with the fuel turned up and 414 cubes can only use 4th on the low side in torque possition in the 9000 pound class, and in the 10,000 pound has to go down into 3rd. I know he's hot, and with a bigger engine. If you watch the track careful, and it it's a sticky or power track, I'd probobly use second on the low side, shift up your torque amplifier, and then if you pull down yank the torque, and keep the thing moving, and take that sled right out the end. Just my thoughts on the matter, but good luck. by the way I'm not sure of the shipping weight of that thing, but If your tires arn't loaded I'd think you'd be well under 10,000
IHBRAD
08-06-2001 07:01:13
3rd low ,pull it in the 10'000 # class if you don't have cloride in the tires you should be very competitive in that class.
the tractor vet
08-05-2001 18:59:50
My 8-0 weights is 11800 with 18.4x34 rears with calsuim and three set of donuts it is a narrow ft with no ft. weigts on the ft. bracket mine is a fast hitch model , i have pulled it in the tug and jerk in the 12500 and used third low with the t/a in the high side and flat out kicked butt. but i will not try the western with it i am out classed them big mean deeres and binders would eat me alive
jeremy
08-06-2001 12:42:10
 Re: Re: First time pulling a 806D need help on what gears????????? in reply to the tractor vet, 08-05-2001 18:59:50
I have one more Question do you start out with the high or low side on the t/a?????
Dale G
08-06-2001 13:37:47
 Re: Re: Re: First time pulling a 806D need help on what gears????????? in reply to jeremy , 08-06-2001 12:42:10
Take off with the torque back and as soon as the rpms come up throw it forward. Good luck!
