A power
06-22-2003 18:06:34
how much power should a 6.125x9 JD A have for power? it has 10:1 comp. and a ported/polished head, and a cam
lynn
06-23-2003 17:49:18
 Re: A power in reply to ?????????, 06-22-2003 18:06:34
????? ???? from 78 to 80 at 975 rpm lynn
06-24-2003 17:16:34
 Re: Re: A power in reply to lynn, 06-23-2003 17:49:18
do you mean engine rpm? we dyno the pto at 540.
lynn
06-26-2003 17:38:48
 Re: Re: Re: A power in reply to ???????????, 06-24-2003 17:16:34
????? ?? yes engine rpm also my dyno reads at 535 rpm lynn
puller
06-28-2003 18:55:12
 Re: Re: Re: Re: A power in reply to lynn, 06-26-2003 17:38:48
do you know where I can get a dyno to buy? I would like it to go up to 150hp. thanks
lynn
06-29-2003 16:49:06
 Re: Re: Re: Re: Re: A power in reply to puller, 06-28-2003 18:55:12
puller..no i don't..they shouldn't be hard to find just about all the dealers around had one..gave $900 for mine 11 years ago and it looked like brand new..lynn
Drew
06-23-2003 17:40:03
Do you have a ported/polished Deere head, Heisler or Jerry's? With the right cam and head porting, it could make 95hp on the top end, but probably wont lug to well. If you set the head and cam up to lug, it may only be in the 80's in HP, but the torque curve will be flatter and it will probably work better for a speed limit class. It all depends on your cam and head as to how much power it will make.
buickanddeere
06-22-2003 20:27:27
530.4 cubic inches should make 133HP at 1500rpm on a overhead two valve engine ..... ....but. That carb/head/intake was designed to supply cheap kerosene to Farmer Brown's tractor's combustion chamber for ploughing the back 40. And the single barrel carb supplying two cylinders with a 180/540 firing order. Should make 70 and maybe up to 90HP depending on the rpms and the porting job/carb/exhaust.
