Info on Simsboro , LA Pull
Krouthead
06-23-2003 04:05:35
Howdy,
RE Simsboro Pull
Is the track similar to Cleaveland? Is it outdoor?Can You stay on site via RV? Typical Mean Green rules,and classes?What time does it start?
Thank You for your help
Krouthead
louboy
06-23-2003 19:42:43
 Re: Info on Simsboro , LA Pull in reply to Krouthead, 06-23-2003 04:05:35
what is the date for this pull
Wide Front SM Puller
06-24-2003 05:22:08
 Re: Re: Info on Simsboro , LA Pull in reply to louboy, 06-23-2003 19:42:43
June 28
Ken C.
06-23-2003 20:42:50
The date is June 28. The track has been red clay sand mix, pulls really good, but always hot. I hear there is a shed over the track now, that will surely help. Ken
06-23-2003 04:46:10
From what I have been told they built a huge shed to cover the track and immediate area, last year without a shed the track started out wet and with the intense heat and humidity the track was bone dry at the end of the day. Some of our members are going down early to help set the track up, it will be as close to Cleveland and Tunica as we can get.
I am not sure of RV parking and start time, but you can count on Mean Green Rules.
I will make some phone calls today and see if I can find out more for you.
Krouthead
06-23-2003 15:39:00
 Re: Re: Info on Simsboro , LA Pull in reply to Wide Front SM Puller, 06-23-2003 04:46:10
Thanks Haynes
Krouthead (Deutz Puller)
06-23-2003 20:42:26
 Re: Re: Re: Info on Simsboro , LA Pull in reply to Krouthead, 06-23-2003 15:39:00
Talked to a fellow member today, not sure of the starting time but we believe it will be after 12 noon, also not sure about RV hookup, but I bet there will be room for an RV, rules should be the same as Tunica, but not 100% sure. I will keep trying to find out and let you know asap. Sorry I was not more help.
