Head gasket sealer????????
Family Traditio
06-23-2003 07:13:39
what kind of sealer do u guys use on your head gaskets?..... ..running 300 lbs. of compression on a U Moline..... .can not keep head gaskets on it.....
Upuller
06-23-2003 07:55:04
 Re: head gasket sealer???????? in reply to Family Tradition, 06-23-2003 07:13:39
All you need is a 3 foot long 2" pipe. Torque the head bolts to 200 ft lbs. Problem fixed.
CHADS
06-23-2003 09:23:25
 Re: Re: head gasket sealer???????? in reply to Upuller, 06-23-2003 07:55:04
I HAVE AN H FARMALL THAT HAS 325PSI, I USE A SOLID COPPER HEAD GASKET, AND EDLEBROCK "GASKACINCH" THIS SEALER WORKS REALLY WELL AND IS INEXPENCIVE. YOU COULD TRY WWW.HEADGASKET.COM TO GET SOME REAL GOOD ADVICE. P.S. I CAN BUILD COPPER HEAD GASKETS. EMAIL ME AT HPULLER@HOTMAIL.COM. FOR MORE INFORMATION GOOD LUCK!
06-28-2003 07:04:56
 Re: Re: Re: head gasket sealer???????? in reply to CHADS, 06-23-2003 09:23:25
what octane of fuel do you use in 325psi?
chads
06-29-2003 07:42:57
 Re: Re: Re: Re: head gasket sealer???????? in reply to ???????, 06-28-2003 07:04:56
we use a mixture of 50 percent ETHANOL and 94ultra sonoco, i have tried c-12 c-16 turbo blue, etc, and I could not get the hp that i get with ethanol and gas
JDGnut
06-23-2003 13:34:57
Are you useing just the copper gasket?? Have some friends running copper gaskets with O-rings.. Most are using a shim stock material... Just curious..
JDGnut
chads
06-23-2003 13:57:08
 Re: Re: Re: Re: head gasket sealer???????? in reply to JDGnut, 06-23-2003 13:34:57
just the copper head gasket I did not need to o ring the block or head
