Degreeing JD G Cam
Curious George
06-27-2003 14:24:51
I'm building a G John Deere [600+ CID] to pull heavy classes at stock RPMS. I'm running a stock cam and my question concerns degreeing the cam for maximum torque/horsepower. How would I determine the lobe centerline spec for the stock cam? I've heard of pullers advancing or retarding one tooth. I've been told the stock cam is good enough. Is there any benefit in a custom grind? Any good advice appreciated.
lynn
06-27-2003 18:18:35
 Re: Degreeing JD G Cam in reply to Curious George, 06-27-2003 14:24:51
george..here is a web address to crane cams..i think you need to add 5 degrees to the cam duration both intake and exhaust and shorten the lobe centers 4 to 5 degrees.....http://www.cranecams.com/instructions/degreeing/degree.htm...lynn
JDBert
06-27-2003 16:56:55
I'd send the cam away and get it ground with that kind of CID and run it 10% over on RPM's you'll be alot happier. We degreed my a the with a wheel just like a car motor. We did have to modify the wheel with a couple of holes to fit the flywheel.
