Has anybody tried hoppin' up an 8N Ford?
Basket Case
06-29-2003 15:54:29
I know,why would you want to,most people ask?I have several pulling tractors and am associated with the ins and outs of pulling.
My daddy always teases me about his N series tracors,he has one (8N)with a bad motor,I am thinking about building it.I am hoping someone has and might help me with at least the donts.
I thinking of max bore with pressed in dry sleeves and block fill.I havent been in one(8N)to know if there is any room for a bigger stroke,is there?Any help would be greatly appreciated.Cmon some body has to pull one.
Been There, Done that
07-02-2003 01:13:51
 Re: Has anybody tried hoppin' up an 8N Ford? in reply to Basket Case, 06-29-2003 15:54:29
Turn down the crank, deck the head, new sleves & pistons, port & polish the intake, carb off a newer series 172, crank up the gov. Easly doubles the HP. You also need a step down trans. since you will be going around 4 mph. in low gear. Or you could replace the 28" tires with 24's.
N Puller
07-01-2003 20:14:08
what club do you pull with.
Basketcase
07-03-2003 01:50:16
 Re: Re: Has anybody tried hoppin' up an 8N Ford? in reply to N Puller, 07-01-2003 20:14:08
Antique Power of the Ozarks is home base,but I pull in many states with many clubs.WHY?
N Puller
07-03-2003 18:21:26
 Re: Re: Re: Has anybody tried hoppin' up an 8N Fo in reply to Basketcase, 07-03-2003 01:50:16
I pull an 8n ford with TATPA and do good in 3100 3600 but 4100 is getting heavy.
earl
07-01-2003 18:55:42
Already to hop up. All you have to do is take vacume plug out of manifold, and put nitros injector in. Put straps on hood so it dont hit you when it blows.
dean
06-30-2003 17:52:19
tried to hop them up when they put inline 6 cyl and flathead v-8 in the funk conversions but the readrends didnt last best move on to something that is stronger and less expensive to repair when parts break
