Diesel supply pump
Jason
06-30-2003 20:47:35
I have a 4020 with 466ci and a 3Lm turbo. My problem is I can't find a good set up for a supply pump to my rossa master injection pump. Anyone have any suggestions? Thanks in advance
dean
07-01-2003 18:34:53
 Re: diesel supply pump in reply to Jason, 06-30-2003 20:47:35
we use 2 holley blue pumps that equal out to about 30 psi or better at the p-pump..which is more than u would use with a roosamaster even with a 450 head on it, also nice over a belt driven in that you dont have to crank the engine to bleed the system..just turn on pumps and go
Jason
07-01-2003 20:35:42
 Re: Re: diesel supply pump in reply to dean, 07-01-2003 18:34:53
Do you run a regulator with the two holley pumps and if so what kind. Thanks
dean
07-02-2003 23:01:28
 Re: Re: Re: diesel supply pump in reply to Jason, 07-01-2003 20:35:42
no as the p-pump has a relief valve that opens for fuel bypass at 55 lbs..run this as a return line to the tank
Scott Williams
07-01-2003 07:25:55
Depends on how much fuel you are trying to use. I have used anything from electric holley fuel pumps, to belt drive pumps. If you will let me know what you are trying to achieve, and how much pressure you want, I'll try to make some suggestions.
