Aftermarket farmall M block
39M
07-01-2003 11:35:59
what is the probability of someone casting an aftermarket M block someday? something cored heavy enough to run very large bores and still run water in the block.also a revised cam location to clear stroker assemblies.the man-hours saved in preparing a stock block could offset a good bit of the intial cost of a new block.i guess i'm just wondering if anyone else shared the same thoughts.
FB
07-01-2003 14:41:46
 Re: aftermarket farmall M block in reply to 39M, 07-01-2003 11:35:59
don't they do that with some moline blocks already?
deadeye
07-01-2003 15:39:11
 Re: Re: aftermarket farmall M block in reply to FB, 07-01-2003 14:41:46
On the Molines, it is a little different. Those jugs are solid with no water in the jug. There is water in the head, radiator, and a circulator pipe. That gives you a lot of meat to bore out or bore on. I think you can go to 5 3/4" if a person wanted to.
