Orland In. Pull ?????
BUDD
07-03-2003 06:23:39
When is the Orland Indiana pull? Date, Time, Classes, and most important what are the rules (hitch height, how far back from center of axle)? I normally pull in the farm stock class, 5000 to 7000 lbs. with a JD "A" & "G" Thanks BUDD
KEVIN BANET
07-03-2003 16:47:52
 Re: Orland In. Pull ????? in reply to BUDD, 07-03-2003 06:23:39
it starts at 9:00 IN.time sat.5"th.scales at 7;00. the rules are more less div.2 but weight on front needs to be resonablee close. 18in. by 18 back.28oo,3500 4500,5500,6500,7500,8500,10000. 10.00 per hook.2 drivers per class.trophies for at least top two tractors. it is on us.327 right by mich.line.their tire sizes 132sq.in 2800,145,in 3500,175 in4500,200 in 5500-6500,252 in 7500,300 in 8500 and 10000.3mph.speed ,NO CUT OR SHARPEN TIRES!
slow mo57
07-04-2003 10:58:32
 Re: Re: Orland In. Pull ????? in reply to KEVIN BANET, 07-03-2003 16:47:52
Kevin I will be back from CA on sunday night give me a call if you take mo let me know how you did.
k banet
07-04-2003 20:12:09
 Re: Re: Re: Orland In. Pull ????? in reply to slow mo57, 07-04-2003 10:58:32
John, Shannon and I are planning on going tomorrow, if the weather permits. Right now at 10:00 it is storming all around us. I will have to call Brian tomorrow morning to check and see if they are going to have a pull. Van Wert got rain out after 4500 lb class and they are not sure if they are going to pull tomorrow because they got 2 inches of rain.
See ya when you get home
Kevin
slowmo57
07-05-2003 15:13:40
 Re: Re: Re: Re: Orland In. Pull ????? in reply to k banet, 07-04-2003 20:12:09
Did you go to Van Wert?No rain hear all week been driving with top down the hole time.Seen alot of things.I am going to try to make it to dads before every one heads back.
kevin
07-05-2003 19:39:37
 Re: Re: Re: Re: Re: Orland In. Pull ????? in reply to slowmo57, 07-05-2003 15:13:40
John, No I did not go to van wert, but we did drive thru the park to see who was all there. We got all of wapakoneta in yesterday, and when we left we ran thru some really bad storms. Van Wert was hit really hard they got over 2 inches of rain yesterday so they cancelled yesterday and today's pull.
Well John slo mo and the 600 got to stay in a dry barn all weekend, but it sounds like Paulding is going to be a go tomorrow, but I can't go because they are pull heavy to light and I have a NTPA pull at Kendallville tomorrow that I have to do because dad is entertaining the relatives.
See ya when you got home.
Kevin
Farmall Daddy
07-04-2003 08:06:56
If it rains tommorro, will you guys still have the pull? Do you have any idea on what the track is like as in did they do anything to it since last year, or is it the same? Thanks for the info!
k.banet
07-05-2003 05:22:51
 Re: Re: Re: Orland In. Pull ????? in reply to Farmall Daddy, 07-04-2003 08:06:56
pull canceled jest got good storm!!
k banet
07-05-2003 04:48:07
as for now it is still a go.brian said that they got very little rain not raining now 6:30 am.
Paul
07-05-2003 05:33:38
 Re: Re: Re: Re: Orland In. Pull ????? in reply to k banet, 07-05-2003 04:48:07
The Orland pull has been rained out. Rain date will be decided later.
