Farmall carb? does 806 carb bottom make big differ
Lee
07-09-2003 12:22:52
I am buuilding a farmall H and I have a 350 carb will a 806 bottom make that big of a difference. what do they cost
ChadS
07-11-2003 18:33:21
 Re: farmall carb? does 806 carb bottom make big di in reply to Lee, 07-09-2003 12:22:52
There is a difference in the bases, mainly in the metering stem. The main jets are a little bigger, not much. If the engine is stock, (no stroker) You should use the 350 carb. If you look back in the past posts from last few days I left a post "timing A Farmall M" It contains alot of info to hop up a Farmall carb. good luck!
FB
07-09-2003 19:57:13
i heard on an m they add 5 hsp, but i nvr tested it
dmp
07-19-2003 20:27:09
 Re: Re: farmall carb? does 806 carb bottom make bi in reply to FB, 07-09-2003 19:57:13
i think thats too much for a stock h. i'd stick with the 350 carb.
