Air presure??
Texas Red
07-10-2003 05:53:11
I have 18.4 34s on my W-9. the tires are filled to the 11:oclock mark. How much air should i run in them to keep the hitch from droping too much whin i load up. It seems to drop too much right now, i have 11 pounds in the now. thanks for the help. TR
Texas Red
07-12-2003 04:01:04
 Re: Air presure?? in reply to Texas Red, 07-10-2003 05:53:11
Thanks for the help. i will be pulling it again in Sept. and will use the advice. TR
JD Puller
07-10-2003 10:09:41
Don't worry so much about how much your hitch drops. The trick is to check out what kind of footprint you have to the ground. Look at the holes you leave when you spin out. What you are looking for is a perfect flat bottom to the hole. If it has a rise in the middle, you are running too little air, and if there is a dip in the middle, you are running too much air.
FB
07-10-2003 19:17:59
 Re: Re: Air presure?? in reply to JD Puller, 07-10-2003 10:09:41
sounds better then jus seeing if your tires "squat"
