Rich or lean
KF
07-15-2003 04:38:48
I have an 88 Oliver that gets condensation on the neck of carb leading into the intake manifold. Does this indicate a lean or rich mixture or something else?
Flogger
07-15-2003 07:36:37
 Re: rich or lean in reply to KF, 07-15-2003 04:38:48
The fuel is vaporizing as it goes through the carb/manifold. Evaporation has a cooling effect which causes the condensation and sometimes ice on your carb and manifold.
Puller
07-15-2003 05:33:27
Something else.
KF
07-15-2003 07:02:32
 Re: Re: rich or lean in reply to Puller, 07-15-2003 05:33:27
Any idea what the something else would be?
Puller
07-15-2003 07:29:05
 Re: Re: Re: rich or lean in reply to KF, 07-15-2003 07:02:32
If the tractor runs good, "something else" is nothing.
KF
07-15-2003 07:33:04
 Re: Re: Re: Re: rich or lean in reply to Puller, 07-15-2003 07:29:05
Thanks, it runs excellent, just wondering what caused the condensation.
G-MAN
07-15-2003 07:51:18
 Re: Re: Re: Re: Re: rich or lean in reply to KF, 07-15-2003 07:33:04
The condensation is caused by that area of the carb being cooler than the ambient air temp, which allows the moisture in the air to condense on the outside of the carb. It's cooler because of the low-pressure present in the inside of the carb in that area, which has to be present for a carburetor to work. I'm assuming that you're running in some fairly hot and humid conditions. The condensation you speak of is what happens before "carb icing", which can affect performance or stop the engine altogether. But, as long as it continues to run good with the condensation on it, you shouldn't have any problems.
RAR/IA
07-15-2003 08:43:21
 Re: Re: Re: Re: Re: Re: rich or lean in reply to G-MAN, 07-15-2003 07:51:18
The condensation on the outside will not bother anything!! Condensation inside with icing can cause problems (primarily on airplanes with piston engines) that is why they have provisions to add manifold/carb heat.
Stick your finger in gasoline and then hold it in the air or blow on it. Feel the cool. Well the engine is intaking so much fuel it results in a lot of cool causing the air to condense on the cool area of the carb.
My 3020 JD has provisions to run a hotter mainfold for winter operation to prevent icing.
RAR/IA
