Cost of a Pulling tractor.
Nick
07-15-2003 13:05:22
I want to build an antique pulling tractor. I want it to be around 5500lbs because that is the most common class around here. I need at least 100hp.
What is the best tractor to built for the least amount of money? What will the total motor cost me to get 100 hp?
dmp
07-19-2003 20:18:09
 Re: Cost of a Pulling tractor. in reply to Nick, 07-15-2003 13:05:22
460 gas with c 301 and 806 carb, get whatever a gas 806 which is like 94 but you could reach 100 with tune up.
ChadS
07-18-2003 16:37:09
Maybe look in to a dennys engine set up. I know people have had alot of problems with what he sells, but for the price for the crank,pistons and rods, and make these parts better, I belive you could build a 100 hp M Farmall for around 4500. A good set up I have worked with is a 7 in stroke, with 4 3/8 bore? (454 chevy pistons) This engine made 110 hp easily at 540rpm.
Hey stupid chads
07-23-2003 11:35:55
 Re: Re: Cost of a Pulling tractor. in reply to ChadS, 07-18-2003 16:37:09
You are a fuc##ng moron if you think Denny has good parts.
ChadS
07-26-2003 08:36:17
 Re: Re: Re: Cost of a Pulling tractor. in reply to Hey stupid chads, 07-23-2003 11:35:55
Apearantly you have never rebuilt a dennys engine, I have! the 409 makes 120hp easily! it is 90 right out of the box! Dumb a$$!!!!! who wouldn't by a 120 hp engine for less than 5000!!
Hey moron
08-05-2003 14:18:43
 Re: Re: Re: Re: Cost of a Pulling tractor. in reply to ChadS, 07-26-2003 08:36:17
Yes you are a f#cking moron. 120 form Dennys juck? Just like your 130 H (that nobody has ever seen) PLEASE, PLEASE learn how to run a dyno, or is it to hard to see the small numbers with your head up your a$$.
ChadS
08-14-2003 15:32:29
 Re: Re: Re: Re: Re: Cost of a Pulling tractor. in reply to Hey moron, 08-05-2003 14:18:43
Thank you for the kind comments.
Adam
07-16-2003 08:19:33
Loaded question here. It's really up to you what type of tractor you like. Family Tradition is right. A Minny U or UB is pretty easy to get a 100 horse out of. Find a G crank to run in one and your set.
Family Tradition
07-15-2003 14:57:31
U Moline
Jason
07-16-2003 12:52:06
 Re: Re: Cost of a Pulling tractor. in reply to Family Tradition, 07-15-2003 14:57:31
I agree with these guys a U Moline is excellent, other good ones are an 88 Oliver or Super M. Those are the leaders around here.
Nick
07-17-2003 07:14:09
 Re: Re: Re: Cost of a Pulling tractor. in reply to Jason, 07-16-2003 12:52:06
What does it cost to built a 100hp MM motor?
What is the cost of a 100hp Oliver 88 or IH M motor?
a puller
07-17-2003 10:29:27
 Re: Re: Re: Re: Cost of a Pulling tractor. in reply to Nick, 07-17-2003 07:14:09
100hp out of a moline might be able to be built from a U for around 1500 in parts + whatever the tractor costs. all you do is pull a g crank out and put it in a U, and switch the heads to better ones then the ge series, and this will be around 80-90hp area. a Farmall M can be done with switching the head, and getting the crank stroked, and popping the sleeves out and finding a set of pistons to run in the block, since they are dry sleeved. an oliver is 6 cylindered and alot lighter then the M or U. you could just do a little bit of polish work and boring, and you prolly would get around 100, but I dont' know since I have never really checked into them. If you plan on building the tractor bigger in the future, the ollie would no doubt be a better choice. Most people use the 88's.
Nick
07-18-2003 08:59:47
 Re: Re: Re: Re: Re: Cost of a Pulling tractor. in reply to a puller, 07-17-2003 10:29:27
I was wanting to know the cost to get 100 horsepower from different tractors. After watching and talking to pullers, I think I need at least 100hp and I want to know the best way to get there. Not 80-90. Do you know what you are talking about or do you just answers because you like to?
ya, I know bour moline an
07-18-2003 10:43:43
 Re: Re: Re: Re: Re: Re: Cost of a Pulling tractor. in reply to Nick, 07-18-2003 08:59:47
ya, all I know is moline and JD.
