Radials??Whats the deal
FB
07-15-2003 17:35:46
Why are radials illegal, do they give a big
advantage or are they unsafe to pull WHAT IS
IT????? ?? Thanx FB
john
07-17-2003 00:28:19
 Re: Radials??Whats the deal in reply to FB, 07-15-2003 17:35:46
They sure seem to pull better than the bias. Everywhere I have seen them they were a REAl advantage. Tractor pulled as if it had an extra 1000 lbs on it. Sounds fair right? Kinda like pullin modified in the stock class.
John
HedgeHog
07-16-2003 05:15:55
Cost,if ya got the money and wanna play with the bigdogs do it,leave the antiques to the hobbiest.
Wide Front SM Puller
07-15-2003 20:04:49
The NATPA mafia and others have made them illegal for some reason, most likely they were beat by someone who had them. Down here in Mississippi we say you can pull either bias or radial, hook it up and give it your best shot, that way you don't have to worry about some pinhead throwing a childish trantrum for some stupid reason.
RoyG
07-15-2003 19:37:44
Raial tires give a lot biffer foot print than a byas ply tire of the same size.
REDMAN
07-15-2003 18:30:04
in the lower power they are a advantage,in high power they are dangerous.
and
07-15-2003 19:59:02
 Re: Re: Radials??Whats the deal in reply to REDMAN, 07-15-2003 18:30:04
and I've never seen a set that had any advantage over a bias set. everyone talks them up but everyone around here who has tried them took them off and put their bias back on.
REDMAN
07-15-2003 21:50:21
 Re: Re: Re: Radials??Whats the deal in reply to and, 07-15-2003 19:59:02
well then you must just be making to much power then,around here they work good in stock classes,add a little power and the like to jump.
Tim
07-15-2003 23:16:59
 Re: Re: Re: Re: Radials??Whats the deal in reply to REDMAN, 07-15-2003 21:50:21
Not sure how they work in pulling but for farming they are unbeatable. Less slip and save more fuel.
Pale Rider
07-16-2003 19:56:15
 Re: Re: Re: Re: Re: Radials??Whats the deal in reply to Tim, 07-15-2003 23:16:59
They work just as good as anything else on a good track and they kick everyone's butt on a bad track. I think they get outlawed because like with a lot of things in pulling ounce someone starts winning with somthing different they just outlaw it instead of buying a set themselves.
07-17-2003 08:30:35
 Re: Re: Re: Re: Re: Re: Radials??Whats the deal in reply to Pale Rider, 07-16-2003 19:56:15
Ditto's Pale Rider.
sweeper
07-20-2003 17:11:33
 Re: Re: Re: Re: Re: Re: Re: Radials??Whats the dea in reply to Wide Front SM Puller, 07-17-2003 08:30:35
I love my radials
Guess Who
07-27-2003 12:13:45
 Re: Re: Re: Re: Re: Re: Re: Re: Radials??Whats the in reply to sweeper, 07-20-2003 17:11:33
The only reason you like radial tires is because you swept house in Simsboro LA
