58 560 D
muleskinner
07-17-2003 13:03:03
O>K> you 560 pullers!!! I just bought a 58 560 D it does not have a turbo, should I put one on or just leave it as is? Also, I have heard that you could get about 140 HP by adjusting the injector pump, is that correct, or just wishful thinking? If you have info for me pls call me on the phone and I will return your call on my nickel. 903-356-5693 or e-mail me muleskinner@ev1.net. thanks
Wishful Thinking
07-17-2003 17:22:25
 Re: 58 560 D in reply to muleskinner, 07-17-2003 13:03:03
I dont see 140 out of just the pump. I dont know about your rules but ours state that if you put a turbo on(not factory) you got to pull in tubo classes. They are 9000lbs.and 10,000lbs.I dont think a 560 has a chance against a 1066 or any of the sort.If I were you I'd bore and stroke it, do some injector work,pump modification and keep it in the classes with the tractors of its weight class.But if you rules permitt this than put a turbo on it.
