880 crankshaft
olliepuller
07-22-2003 06:24:02
Did oliver make a larger crank that would fit
the 880 from a larger engine (waukesha)?
looking for 4 1/4, how many bolt main? stock of course is 4"
Lynn
07-22-2003 20:52:49
 Re: 880 crankshaft in reply to olliepuller, 07-22-2003 06:24:02
I have one of the 99 oliver/1100 massey/195gk crankshafts. It has 4-5/8 rod journals and is ground .010 under. Also have a head off of the same engine that is in excellent shape including the manifold. E-mail if interested.
bigmotors
07-22-2003 14:08:01
Use a Oliver "99" or a Massey 1100 gas crank.
You can get up to a 4.625 just by off set.
Only 4 mains. Bolts right in. Some of the cranks are cross drilled. Both are Waukesha motors.
P.S. have some laying around if you need one.
Good Luck!
olliepuller
07-23-2003 12:45:05
 Re: Re: 880 crankshaft in reply to bigmotors, 07-22-2003 14:08:01
shoot me an email on price
pjobssas@yahoo.com
TimC
07-22-2003 09:31:22
You have the option of offset grinding to get 4.250 assuming you can get a rod .125 shorter with a journal that is the right size.
The grinding should be cheap enough if you could get the rods. I believe you would find the 4 main stronger than the 7 main.
I know this is not what you were asking but it is an option.
Jason
07-23-2003 07:24:42
 Re: Re: 880 crankshaft in reply to TimC, 07-22-2003 09:31:22
I have heard that you can take one of those 195 or 1100 cranks and weld it up then turn it down to a 2 in rod journal and with a VAC Case rod, 1 5/8 stroke is possible? Does anyone know this for sure? I have some of these cranks and I am looking for a good combo. Thanks for any help.
TimC
07-23-2003 08:49:34
 Re: Re: Re: 880 crankshaft in reply to Jason, 07-23-2003 07:24:42
I have seen .625 stroke added to a 1100 motor and a rod out of a COOP tractor. Not sure which pistons were use and I don't know if the deck height is the same as the 88.
Alloverher
07-22-2003 06:37:18
A seven main crankshaft will fit into a four main crankcase. Just weld the oil hole closed on the unused mains.
A.P.
07-22-2003 12:08:50
 Re: Re: 880 crankshaft in reply to Alloverher, 07-22-2003 06:37:18
Tap the hole and put a set screw in it using Locktite. Easier than trying to weld it and reversable to boot.
A.P.
