Allis Chalmers WD 45 Press Steel Wheels
Rod
07-25-2003 18:43:42
Did any of the 1953 WD45's come with press steel wheels? If so where could find a set?
Thanks
Larry806
07-28-2003 07:44:39
 Re: Allis Chalmers WD 45 Press Steel Wheels in reply to Rod, 07-25-2003 18:43:42
I have several set's of pressed steel wheels that will fit a WD most with good tires on them I'm in Ohio
Allis Puller
07-26-2003 22:28:34
I pretty sure they did'nt but you can buy them, The cheapest way to go is find a gleaner combine - but they will be 26" and usually 16.9's.
Dave ___ MI
07-26-2003 18:04:19
None of the WD-45's of any year came with pressed steel wheels. It's trud some of the Gleaner wheels may fit.
ChadS
07-26-2003 18:14:48
 Re: Re: Allis Chalmers WD 45 Press Steel Wheels in reply to Dave ___ MI, 07-26-2003 18:04:19
well they did have a pressed steel center, but I think it was a power adjust rims. There was spokes, cast centers, and pressed steel power adjust rims. Is it true that AC had 36s or 38s from the factory? ChadS
Jimmy
07-27-2003 13:09:44
 Re: Re: Re: Allis Chalmers WD 45 Press Steel Whe in reply to ChadS, 07-26-2003 18:14:48
Yes, 10 X 38's were an option.
ChadS
07-26-2003 10:31:11
I think they did. You may find rims for it off a combine with 8 bolt rims, Chads
