Extrude Honing
raju h p
08-23-2001 02:19:15
whether extrude honing and abrasive flow maching are one and the same.If so, tell me some references where I can get more details about this
raju h p
08-25-2001 08:20:13
 Re: Extrude Honing in reply to raju h p, 08-23-2001 02:19:15
whether extrude honing and abrasive flow machining are different names representing the same process?
low buck
08-25-2001 05:57:30
Extrude hone is expensive:$800 for intake exhaust on a four cylinder, solution would be to find a sandblasting shop and have then sand blast your manifolds.
Todd
08-26-2001 09:18:33
 Re: Re: Extrude Honing in reply to low buck, 08-25-2001 05:57:30
I never though sandblasting would do much because the longset wearing tips for sandbasters are made out of cast iron-the same material the manifolds are made from.
pete D
08-23-2001 04:58:36
web site extrudehone.com will give you info and prices. used to be more expensive prices have come down. some persons/engine builders think they can produce a better finish by hand. the acid test is before and after flow testing and dyno testing.
