Shaving Tires
George
08-24-2001 06:18:10
Does anyone know how I could go about shaving the top of the lugs on the rear tires? Basically, I want to re-profile them, as they are badly worn such that they are rounded off. All I want to do is flatten the top. What can be used to do this? Thanks.
George
08-27-2001 18:37:19
 Re: Shaving Tires in reply to George, 08-24-2001 06:18:10
Thanks for the help, folks!
Slo
08-26-2001 06:54:17
I have always used a chain and a piece of rough concrete, that way they are not techninically cut tires. Make sure that you spin the tires in reverse, or spin them around and then use a forward gear. I used to do a lot of blacktop pulling, and would turn the tires around backwards. Not only did it wear down the back side of the lug, it sharpened the leading edge for dirt tracks.
BS
08-25-2001 18:38:13
BuY NeW TiReS JaCkHoLe.
Todd
08-26-2001 09:12:36
 Re: Re: Shaving Tires in reply to BS, 08-25-2001 18:38:13
What kind of puller are you? Most people know new tires are the worst thing for pulling. Now go crawl back under your rock. If you can't say something helpful stay away.
billy
08-25-2001 10:20:12
johny bob
08-25-2001 10:18:14
i have never heard of anyone shaving there wiskers with a tire. could you give me more info on it it sounds like fun. what gear do you shave in? does it hurt? do you ever get razor burn?
You stupid moron.
08-28-2001 14:00:32
 Re: Re: Shaving Tires in reply to johny bob, 08-25-2001 10:18:14
Can't you read? He did not say shaving WITH a tire. He said "Shaving Tires". How dumb can you be? Shaving tires is what you do when the hairs on your tires get to long. A nice close shave will make your tires look nice and clean. And NOBODY wants rattie looking tires.
I would suggest using hot shaving cream to soften the hairs before you shave.
Lee
08-24-2001 13:53:07
A Makita electric wood plane works great.You can use the Epperson discs to finish the job,and get the edge you want.
Dale G
08-24-2001 09:35:17
You can call Epperson Tire 937 855 4326 they can sell you a grinding disc for the top of the lug and a grinding cup for the front of the lug if you want one.
al
08-24-2001 06:23:30
TO START WITH...YOU CAN TAKE THE ROUND EDGES OFF BY SPINNING THEM IN REVERSE ON CONCRETE..BE SURE TO HAVE SOME WEIGHT ON THE TIRES AND CHECK THE INFLATION FIRST....THIS WILL GET YOU STARTED..GO A LITTLE AT A TIME AND WATCH THE BARS FOR EVEN ...IF YOU WANT A PROFESSIONAL JOB ..THESE PEOPLE USE A JIG AND CAN DO ANY WAY YOU WANT..AL
