Farmall H Front/Rear Hubs
Paul A.
08-11-2003 10:33:23
I'm trying to lighten up my Farmall H, could anyone tell me which 5 or 6 bolt hubs will fit the front axle, and what 9 bolt hubs will fit the rear axle? I recall someone telling me the rear hubs from an Oliver will fit the H, but I can not recall which models. Thanks, Paul.
Ohio M Puller
08-12-2003 06:49:17
 Re: Farmall H Front/Rear Hubs in reply to Paul A., 08-11-2003 10:33:23
I sent you an email with a frontend option.
Ohio M Puller
Francis
08-13-2003 07:03:18
 Re: Re: Farmall H Front/Rear Hubs in reply to Ohio M Puller, 08-12-2003 06:49:17
Hey, Ohio M Puller, Could you include that here? I don't have e-mail, is it short enough to post here? I'm fixing up an "H", too. Thanks much.
Ohio M Puller
08-13-2003 11:08:22
 Re: Re: Re: Farmall H Front/Rear Hubs in reply to Francis, 08-13-2003 07:03:18
We build light weight frontends for Farmalls. All I need to have is your bolt pattern layout for your lower bolster (yes some are different than others). The frontends are $250 with 5 bolt hubs that Ford rims will mount on. I also have an outlet for 12" 3 ribbed tires that will fit nicely. This will drop the frontend considerably as well as drop weight. The rims and tires are an additional $150. If you have your own rims and tires make sure you tell me the size call me if anyone else is interested 419 295 4592
Ohio M Puller
Adam Coleman
AC
08-11-2003 14:56:14
I think oliver 77 hubs for the rear...AC
