ChadS
08-19-2003 21:36:06
Re: Can M Rearend be Locked?? in reply to terryjd98, 08-17-2003 20:13:44
The kits we offer, are safe, and strong, it can handle up to 800hp!!! For an M, I would need your brake pinions and brake hubs, (both sides) for machine work, the differential is not affected by this kit, no damage will result!!! Tested, and True. My opinion, it is just as essential to have posi/limited slip, as to have a big hp stroker engine. Posi trac, work if you are running over 10mph, but the problem is, you can't steer it!! This kit allows you to use your brakes to correct on the track, and as soon as the brake is released, the clutch reenguages back to the desired setting. You are able to steer the tractor as normal. Limited slip works the best for under 10mph, The more you put power to the ground, the better you get, More control over the tractor, less weight placements. Hope this helps, email me at hpuller@hotmaol.com for more information. Chads
