HELP!! Need compression ring for power block urgently!!
Luke
08-28-2001 18:50:43
I have a power block on a 1941 A and on one piston has the top compression ring broken. I believe it is a chrome ring too. Anyone know where I can get another ring for it? If you have one for sale also I would greatly appreciate a reply soon. Thanks a million.
WTW
08-29-2001 07:34:48
 Re: HELP!! Need compression ring for power block urgently!! in reply to Luke, 08-28-2001 18:50:43
Luke, A 720 or 730 gas John Deere tractor used a 6" bore. They were a thin ring like the original power block A piston used and the top ring was chrome. Be sure to check the width when comparing but I know some of the rings will work as I have used them for this application. Good Luck Dave W.
Mike in Mo
08-29-2001 05:28:45
Luke try Total Seal in Phoenix. I got rings for my power block from them. Phone # 1(800)874-2753.You'll need to give them the bore size and ring width as they won't have a listing for your specific application but just by size of your old ring. Mike
shohn
08-28-2001 20:02:24
hey, sorry, no info, but i was wondering where you got your power block, i have a 50 a, and i want ojne, what classes do you pull in? what division. thanks shohn sorry no help
Luke
08-29-2001 14:31:41
 Re: Re: HELP!! Need compression ring for power block urgently!! in reply to shohn, 08-28-2001 20:02:24
Here at home I pull in the lightweight div around 5000 pound, but I can also weight up heavier to make middle weights. I could pull heavys (8010#) but I would take a chance on breaking more than I would be winning so I don't do it. This coming pulling season I am going to get in the Ohio Antique Pulling Circuit and the told me I would still be division 2 I believe it was with just a power block and 15.5 tires. If you go with heisler heads, johnson manifolds, etc. you will more likely pull division 4.
