Boring a JD 70 powerblock
Dave Hathaway
08-24-2003 15:19:38
I have a JD 70 powerblock (6-1/2") bore and just purchased a pair of 6-3/4" pistons as I want to bore the block .250 over. The larger pistons are 3/4" longer from the center of the wrist pin to the head of the piston than the pistons that are in the block now. If I bore the block 3/4" deeper, the boring will go beyond the spark plug ports. I'm assuming this won't work. Do I need to shorten the connecting rods? I'm new at this - thanks for any help you can offer.
a puller
08-24-2003 18:47:59
 Re: Boring a JD 70 powerblock in reply to Dave Hathaway, 08-24-2003 15:19:38
you can have someone turn off some of the head of the piston to fit.....
