14.9 vs 16.9 tires
John
08-26-2003 17:54:47
I pull the 4500-6500 classes. What tires do you think have the advantage??? 14.9-38 or 16.9-34....Any opinions out there... Seems the taller tire might be better??? Thanks in advance...John
sos -n.a.t.p.a. puller
08-26-2003 19:35:08
 Re: 14.9 vs 16.9 tires in reply to John, 08-26-2003 17:54:47
14.9 are your best bet up to 6500 lbs they will hold to the track the best 16.9 are to wide you cant get enough weight per square inches on your tires to the track P.S been there done that former n.a.t.p.a 5,000 5,500 points.champion hope this helps oliver puller
John
08-27-2003 13:40:29
 Re: Re: 14.9 vs 16.9 tires in reply to sos -n.a.t.p.a. puller, 08-26-2003 19:35:08
Thanks, I think the 14.9's are the way to go also. Just needed a second opinion....John.
