7.5 stroked crank for M
IRISH RED
08-27-2003 20:15:05
Where can I get a good high quality 7.5 stroked crank for an M or who does good work to make one also were can I get rods for this and is it possible to bore a stright M block to 4.25? building my own motor to pull open classes any info greatly appericated.
Chads
08-29-2003 17:28:53
 Re: 7.5 stroked crank for M in reply to IRISH RED, 08-27-2003 20:15:05
C&P machine in Fort Wayne Indiana does a super job on stroker cranks, Great service, and turn around. They have done all 3 of my H cranks, no complaints so far!!! ChadS
Red Rider
09-08-2003 08:04:44
 Re: Re: 7.5 stroked crank for M in reply to Chads, 08-29-2003 17:28:53
Chad, do you have a phone number for C & P Machine?
IRISH RED
08-30-2003 15:47:25
were can I get a hold of c and p do you have there number THANKS FOR THE INFO
Flyin Farmall
08-28-2003 17:02:33
Yes you can bore a straight M block to 4.25".It may get a little thin at the bottom though,so just be careful!
randy hall
08-28-2003 09:08:41
for a good job on a crankshaft you need to get ahold of keith merfeld.
bolts in crank?
08-29-2003 05:48:27
 Re: Re: 7.5 stroked crank for M in reply to randy hall, 08-28-2003 09:08:41
saw a merfield crank at colombia, mo last spring. wenzig had it there i think. merfield laid bolts on the journal to get the welds out there quicker....very interesting?
WILDMAN
08-28-2003 04:42:31
PAUL WILL ONLY DO COMPLETE MOTORS . HE WILL GET THE HP OUT OF IT. STAN BLADES AT CUSTOM CRANK IN MISSOURI DID MY H CRANK 3YRS AGO NO PROBLEMS.
IRISH RED
08-28-2003 20:10:11
 Re: Re: 7.5 stroked crank for M in reply to WILDMAN , 08-28-2003 04:42:31
were can I get in touch with Stan Blades thanks for the help
supermpuller4
08-27-2003 20:28:59
Lemmom's Tractor Rushville, In 765-938-1808 Ask for Paul
Blowby
08-29-2003 04:43:09
 Re: Re: 7.5 stroked crank for M in reply to supermpuller4, 08-27-2003 20:28:59
Sounds like you need to talk to the "cylinder doctor" in Manchester, Michigan. He can hook you up with awesome 7 1/4" cranks! Just an idea.
