Rebuilding farmall 400 for pulling.
Tom Hough
08-29-2001 19:05:48
I just bought a farmall 400 for pulling.
The engine needs rebuilding and i was looking for some tips to gain some added power,but not go too crazy.
I'm new at this and only plan on going to a couple of pulls a year. Thanks!
Dale13
08-30-2001 11:57:13
 Re: rebuilding farmall 400 for pulling. in reply to Tom Hough, 08-29-2001 19:05:48
I did a Super M last year,thats about the same casting as your 400. I'll tell you what I did and what I wish I'd done.
Did. Milled the head .180,three angle valve job,smoothed the ports out a little. A good carb job,polished venturi etc. A M&W 4.125 piston and sleeve set. Advanced cam timing 1 tooth.
Wish I'D done's 4.25 pistons and sleeves. Chevy valves. I've done well pulling 8 first's 2 seconds 2 forths and 3 did not place. that extra HP form the 4.25 bore would be handy. You can use Chevy 409 pistons without sleeves if you want to save a little $$.
Flyin Farmall
08-30-2001 18:40:51
 Re: Re: rebuilding farmall 400 for pulling. in reply to Dale13, 08-30-2001 11:57:13
Dale,
could tell me a little more about the Chev 409 pistons in the M? is pin size the same?do I need custom rods?,what about the valves?thanx in advance.
Dale13
09-01-2001 19:29:12
 Re: Re: Re: rebuilding farmall 400 for pulling. in reply to Flyin Farmall, 08-30-2001 18:40:51
No you do not need custom rods,the compression height is the same and the pins are 1" same as 400 and 450 .The M and SM pins are larger but you bush them to size. The downfall is then you have the groove where the sleeve flange was,I was told that you can have the flange machined off the old sleeves and 271 locktite them in place and the head gasket and head will then hold them in place.
Chuck M
09-03-2001 04:43:15
 Re: Re: Re: Re: rebuilding farmall 400 for pulling. in reply to Dale13, 09-01-2001 19:29:12
Can 248 block be bored the same way?
