Farmall 1206 injector pump
Chad
09-01-2003 19:26:28
I got a question on the injector pump on a 1206, I need to know where the "smoke" screw is and how much do I dare turn it (out or in??) for a farm stock pull. It has a roosa-master pump on it.
This is the first time I have pulled it and just what a little more since I have to face about 6 1066's in my class.
Thanks for any help.
REDMAN
09-02-2003 18:09:33
 Re: Farmall 1206 injector pump in reply to Chad , 09-01-2003 19:26:28
the roosa-master pump is a little tricky to open up,i'd suggest getting one of the dealer mechanics to walk you through it.you can turn it wide open without hurting anything,but if you are going to play with that many 1066s you will be a little short on power as a 1066 is capable of around 230 with the pump open.
Chad
09-02-2003 19:28:16
 Re: Re: Farmall 1206 injector pump in reply to REDMAN, 09-02-2003 18:09:33
Hey REDMAN, any idea what my 1206 would top out at for horsepower with the pump turn all the way up? Just curious, it doesn't really matter since I just go for fun. I got talked into making weight bars and loading it up to the 15,000 farm also, I know there will be a 7220 magnum in that class, ought to be fun.
