GEAR REDUCTION STARTERS
OPBRIEN
09-02-2003 12:05:58
DOES NAYONE HAVE A IDEA WHERE YOU CAN GET THE INSIDE GEAR FOR THESE STARTERS. IT CAME OFF A 450 IH WITH 6 VOLT STARTER DELCO REMY NO. 1108038 ANY HELP WOULD BE NICE, PLEASE LEAVE A MESSAGE ON THIS BOARD. PULLING TRACTOR WILL NOT START WITHOUT THIS AND I HATE A CHAIN!!!!!
kent
09-10-2003 19:59:22
 Re: GEAR REDUCTION STARTERS in reply to OPBRIEN, 09-02-2003 12:05:58
Green Magazine had an article on gear reduction starters for top mount starters on two cylinders if you have a green tractor.
randy hall
09-03-2003 11:00:01
you evidently have a a&w or a m&w gear reduction starter. there are two different size pinion gears on the a&w. you need to count the teeth to see which one that you have and maybe i can help you out.
opbrien
09-04-2003 15:28:22
 Re: Re: GEAR REDUCTION STARTERS in reply to randy hall, 09-03-2003 11:00:01
well we have half a gear left and it has 14 teeth on that piece any help you have would be great.
