Accel 12V coil w/6V points
jason
09-04-2003 18:11:22
I have converted both of my IH tractors from 6v to 12v systems. My H has a Delco Remy distributor and my M still has the factory IH distributor. I bought a standard 12v coil for my H and an Accel high performance coil for my M, since I pull it. I have put around 25hrs on my H and have not had any problems with points or condensors, but several people will tell me they will burn up. I was wondering what I need to do to do it right or will they be fine?
TimC
09-05-2003 13:14:49
 Re: Accel 12V coil w/6V points in reply to jason, 09-04-2003 18:11:22
They will only burn up if you leave the ign on and walk away for an hour or so. The points don't know the differance in 6 or 12. They do burn up if they have a constant load (such as the coil) for an extended period of time. For a little hotter spark use a coil that doesn't have a resistor built in.
Doug in OR
09-05-2003 11:40:00
I doubt you will have any trouble. Considering that a 12 volt coil is merely a 6 volt coil with added resistance, the points will not see much difference. For what it's worth: you probably would have gotten a bigger bang if you would have installed an electronic ignition module instead of the points, and used a regular 12 volt coil.
Jason
09-07-2003 19:06:25
 Re: Re: Accel 12V coil w/6V points in reply to Doug in OR, 09-05-2003 11:40:00
Anyone know where to get the electronic module to convert from points.
