Can a WD45 do any good at the pulls?
wonderboy
08-31-2001 19:11:49
I was wondering if anyone out there pulls a WD45. If so, are you competing well with the other guys. All I hear about is John Deere,FarmAll and Oliver. Would I be wasting time trying to pull my 45? Does anyone know why they make 45's pull in the 4500-6000 class, when mine weighs slightly less than 4000 pounds. Thats what they do around my county anyway. Franklin County Indiana.
KB
09-04-2001 13:56:13
 Re: Can a WD45 do any good at the pulls? in reply to wonderboy, 08-31-2001 19:11:49
The AC's WD, WD-45, and WC are great for pulling. They can have a lot of power for not much money and most pullers with limited budgets like that alot! Your 45 has a lower 1 st gear than the WC's and most WD's so that will help you in the heavier classes.
AL
09-04-2001 09:34:40
A WD/WD45 CAN PUT OUT AN EASY 60HP WHEN SET UP RIGHT....I PULL WITH 38 INCH RUBBER AND HAVE PLENTY OF POWER UP TO 5500..DOES REAL WELL IN THE 4500 RANGE...I CAN GET IT DOWN TO 4000 BUT IS TOO LIGHT TO COMPETE...LOVE TO BEAT MY FRIENDS WITH 6 GEARS..AL
Dale G
09-04-2001 06:59:02
Look in the HOOK magazine pull results.The WD's and WC's dominate in the 3500 and 4000 cut tire classes.
Kyle Jacobson
09-02-2001 13:37:50
Yes it pulls good.
Lawnman
09-02-2001 11:11:32
build and weight it right and they will do good in the 4000 to 5000 lb.classes. Running in stock classes they will nver run out ot power.
Emptypockets
09-02-2001 06:09:23
check out picture tb01038 on page 2 and make a dream come true, go to:
Link
James
09-01-2001 20:22:12
They can be stout tractors. I have pulled agenst a few they do good in the lighter classes but when the get into the 6000lb and up they can't compete.
semo puller
09-01-2001 20:11:11
It just depends on what class you want to pull.farmer stock class you can get right in there and do very well.4 MPH cut tire class you can make a very very good running machine.open class you can make a great 3500=4000 machine just by calling southeast missouri.
Ken
09-05-2001 20:06:57
 Re: Re: Can a WD45 do any good at the pulls? in reply to semo puller, 09-01-2001 20:11:11
do you have any pulls soon. you can come to Paducah Sept 21 and 22 Gas and steam eng. show yea . thay have a pull
A-C
09-01-2001 12:24:02
Stock to stock in a field plowing contest they are almost impossible to beat but on a pulling track high dollars are what wins and there does'nt seem to be many Allis people with money to blow on pulling but in southeast MN there are a couple of guys who do very well with WD & WD45.
Jordan
09-02-2001 07:03:22
 Re: Re: Can a WD45 do any good at the pulls? in reply to A-C, 09-01-2001 12:24:02
I have to agree on the plowing part. I watched a plow day once with many JDs, some Farmall, one MM, I think a Ford or two and one AC D-15. The D-15 was pulling a 3-bottom twice as fast as the Johnny Poppers with 2-botton ones, not to mention they were constantly on and off the tractor making adjustments with the D-15 cruised right along.
Jordan
ACD-17
09-03-2001 12:37:23
 Re: Re: Re: Can a WD45 do any good at the pulls? in reply to Jordan, 09-02-2001 07:03:22
Beating JD in the field has always been easy. When you can beat a big Farmall then that is something. Dad switch from IH to AC back in the early 60's. His brother-in-law had a WD-45 and Dad had a Super M and when that little "bucking bronco", as he called it, plowed so much faster and used less fuel he had to have one. A couple of years later Dad had a WD-45 too and then a D-17IV. The D-17 was even more suprising.
DangerWillRobinson
09-02-2001 07:44:16
Pulling plows are as about as fun as watching grass grow.
Alex
09-02-2001 20:08:09
 Re: Re: Re: Re: Can a WD45 do any good at the pulls? in reply to DangerWillRobinson, 09-02-2001 07:44:16
That's probably true for some...what city do you live in?
OrangeCrush
08-31-2001 21:34:51
If you wanna pull get you a diesel one. I pull mine from 4000 to 6000 and i compete with some tough 88's. But it mite do so well cause i got a Turbo.
