GVI pulling engine
Tyler Neff
09-07-2003 11:22:25
My 1st question is there 6in crank that moline makes that will fit in a GVI.2nd What will have to be done as far as grinding goes inside the crankcase to fit a 6in crank in it? 3rd I think if I use a 5.75 piston I should have around 900ci does anybody know how much HP I should have (rough idea).4th is it difficult to put 5.75 pistons in a GVI? Was there ever a gasoline GVI made or will I have to use LP?If ive left something out please feel free to give me your 2 CENTS worth Ive never built one of these and any additional info would be nice .Plus if you know of someone who has one built that would like to sell or do some tradin let me know Id be very interested
THANX TY
Mopower
09-08-2003 10:14:39
 Re: GVI pulling engine in reply to Tyler Neff, 09-07-2003 11:22:25
Tyler,
A 605 (power unit) crank (or whole engine) will fit in yours. I believe an 800 crank requires an 800 motor but I'm not positive. A 605 is like a 4cyl tall block G motor, 6 cyl. It was not used in regular production tractors often. If you are going with such a big motor an 800 power unit might work easier depending on your wallet and local rules. If you want specifics on what fits what, I can help some.
Ethan Berry
517-726-0484
piston
09-07-2003 19:24:24
havbe a 800 gvi for sale needs a new hood ready to pull took it from lp. to gas hole left in hood.where tank was . has big carb 4210 heads, 20 38s on 18 inch rims. call 870 425 8025 days for price.
USE THE CLASSIFIEDS
09-08-2003 11:29:23
 Re: Re: GVI pulling engine in reply to piston, 09-07-2003 19:24:24
This page isn't for classified ads!!!How many times ,do I have to tell you people.
Preacher
bo nuts
09-09-2003 09:16:58
 Re: Re: Re: GVI pulling engine in reply to USE THE CLASSIFIEDS, 09-08-2003 11:29:23
use the classifieds shut up dumb@#$
a puller
09-07-2003 18:32:29
you should have about 200 or so horse if you can get it. I believe an hd800 had a 6" crank, I think you can just drop it in the tractor the whole motor and have 175hp stock strait off the pump.
is it a myth???
09-08-2003 13:46:44
 Re: Re: GVI pulling engine in reply to a puller, 09-07-2003 18:32:29
there is a guy in our club with a gvi that the last owner claimed to have 300 hsp....it is in the tractor pics....but it doesn't matter he is puttin a bigger motor in 1000++
It's true
09-08-2003 19:54:50
 Re: Re: Re: GVI pulling engine in reply to is it a myth???, 09-08-2003 13:46:44
A HD800 will put out 250HP stock. If you tune it right, you can get 300. A HD bored and stroked to 1000cid can make 450HP.
Nick
09-08-2003 14:37:07
I have seen them on the dyno at 300 with the 800D motor Reworked. I got one that is stock stroke and bore just injection pump and intake work done with it and it runs at 145HP.
Funny
09-09-2003 05:38:51
 Re: Re: Re: Re: GVI pulling engine in reply to Nick, 09-08-2003 14:37:07
That's funny, you have a engine they never made.
Hillbilly Hooker
09-08-2003 20:03:52
Did i misunderstand? You got an 800 diesel?
Tyler Neff
09-09-2003 18:47:33
 Re: Re: Re: Re: Re: GVI pulling engine in reply to Hillbilly Hooker, 09-08-2003 20:03:52
What are the engine specs on a G1000 engine?
Tyler Neff
09-09-2003 18:46:27
Hillbilly Hooker
09-10-2003 20:01:31
 Re: Re: Re: Re: Re: Re: GVI pulling engine in reply to Tyler Neff, 09-09-2003 18:46:27
I think they had the 504 engine
