A JD, power block?????
AJDPULLER
09-03-2001 18:23:07
i need a A john Deere power block, the biggest i can get. i am geting a g carb also. any other hints for horse power? thanks shohn
Pullman
09-04-2001 18:44:30
 Re: A JD, power block????? in reply to AJDPULLER, 09-03-2001 18:23:07
I have a JD powerblock that i'd be willing to sell. It's the biggest made. I was gonna put it in my A but i'm gonna sell it because i because i've decided to leave it all stock. Oh, i also have a set of aluminum pistons for it. I'll take $250 for the whole outfit.
AJDPULLER
09-04-2001 20:22:17
 Re: Re: A JD, power block????? in reply to Pullman, 09-04-2001 18:44:30
i thought of some other questions, would you have to install a water pump to keep it cool plowing and how big are the pistons? are they "g" pistons? or are they ones that would fit without boreing it out
thanks shohn
AJDPULLER
09-04-2001 20:18:04
hey, where you from, i am interested in it. i would be willing to pay 250. are you sure you dont have to cut the frame to get it in? i heard some you did. thanks shohn
Leroy
09-05-2001 15:07:29
 Re: Re: Re: A JD, power block????? in reply to AJDPULLER, 09-04-2001 20:18:04
A number 1 power block has a 6 inch bore. G pistons are 6.125 so you'll have to bore the block. You don't have to cut the frame to install it. Go with the big nut card, Heisler Head and Heisler or Johnson Manifold. No need for a water pump. $250.00 is a steal for a Power Block don't pass it up!!!
AJDPULLER
09-05-2001 15:23:16
 Re: Re: Re: Re: A JD, power block????? in reply to Leroy , 09-05-2001 15:07:29
thanks for your help leroy pullman, is it a # 1 power block? please get back with me. you can email me at limule50@hotmail.com, i am interested in the head.
pat
09-05-2001 15:30:26
 Re: Re: Re: Re: Re: A JD, power block????? in reply to AJDPULLER, 09-05-2001 15:23:16
Dear APULLER,
You did not state which year your tractor was, for there are three different powerblocks-1 for each bolt pattern
Pullman
09-05-2001 15:28:51
I had the powerblock bored out to the max and the pistons fit it.
AJDPULLER
09-05-2001 17:12:24
 Re: Re: Re: Re: Re: Re: A JD, power block????? in reply to Pullman, 09-05-2001 15:28:51
thanks pat. what year dose it fit? i have a 1950 A john deere. where do you live? if it is the right one then ill take it for 250
Pullman
09-05-2001 18:22:47
 Re: Re: Re: Re: Re: Re: Re: A JD, power block????? in reply to AJDPULLER, 09-05-2001 17:12:24
My A is also a 1950, so its sure to fit. I live in Rushville, IN.
AJDPULLER
09-05-2001 19:11:06
 Re: Re: Re: Re: Re: Re: Re: Re: A JD, power block????? in reply to Pullman, 09-05-2001 18:22:47
WOW WOW! i live in rushville Indiana too, whats your name? i am Shohn Busald, my dads john and grandpas richard. write back and we will set a time and place, ill, take it for that, do you by any chance know what the diameter is on those pistons? thanks shohn
