dale 13/M building
Flyin Farmall
09-04-2001 20:16:18
Dale,what valves did you use?did you ever build one with the 409 pistons?do you just knock the sleeves out and size the holes or what?what would you use for carb?I am building an M for next year,and want to know as much before I start sticking $$$$$!thanx alot for info!
Dale13
09-06-2001 13:03:35
 Re: dale 13/M building in reply to Flyin Farmall, 09-04-2001 20:16:18
Go to a good machine shop and let him guide you as far as the valves go.Yes the pistons run in the block without sleeves. Use your M carb with 806 complete rebuild kit to start. The head you want is a 450 LP if you can find it and can afford it,if not go with a 8060 casting #. Have said machine shop mill[do not mill a 450 head] .180 to .200 thousandths. Make sure the distributer is in good shape as far as bushings go and that the advance is functional,would be a good idea to have that worked on,new advance curve,more of it and a little sooner.RUN GOOD GAS as good as you can afford,Sunoco clear is good for the compression you'll have. Do away with the sediment bowl and installa 3/8" line and in line fuel filter. These are good starting points,remember SAFTY first. It has to steer and stop before you make it go!! And wheelie bars!!!
Flyin Farmall
09-06-2001 16:53:08
 Re: Re: dale 13/M building in reply to Dale13, 09-06-2001 13:03:35
thanx Dale!!i've heard of using the bottom of 806 carb,but if kit is just as good,thats way to go.what about governor?is Denny's a waste of $$$? has anyone used his header,or is it just junk too?
Chuck M
09-08-2001 07:54:41
 Re: Re: Re: dale 13/M building in reply to Flyin Farmall, 09-06-2001 16:53:08
Flyin Farmall are you going to do your own machine work?
Dale13
09-07-2001 03:38:59
E mail me for more info please.
