Farmall H Pulling Tractor
Mez25
09-23-2003 12:32:03
I recently purchased a Farmall H, of which I intend to use for tractor pulling. I have been unable to determine the date of it yet, but with some more research I may be able to. The tractor was completely restored (2) years ago and it was done by a man with a machine shop. They bored out the heads and placed larger performance pistons in the tractor, but they did not place a larger cam or rockers in the tractor. I just bought new 13.6-38 pulling tires and placed them on new 11 inch rims. I also was able to find an updraft airplane carb with K&N filter. I am going to pull the tractor this weekend for the first time and I was wondering how anyone felt I would do. I am nervous about the tractors performance. Can I start in 3rd gear in the 4500 lb. class? Also when it was restored, there were all new gears placed in the transmission and they put an M size manifold on the tractor. Let me know what you think.
Dedicated to M.L.
Farmall Daddy
09-25-2003 08:27:27
 Re: Farmall H Pulling Tractor in reply to Mez25, 09-23-2003 12:32:03
I have a M that is setting at around horsepower and it has a hard time taking second gear in the 5500 pound class. Unless I find a track that is rather loose, I stay in first gear. I know a guy that has an H with a 350 motor, bored out, not stroked and he stays in first gear most of the time and does pretty good. Good luck!
Donnie
09-24-2003 07:32:18
Ok I give up. How did the put a "M" size intake on an H? The carb would not line up with govener. What style of govener are they useing with the airplane carb? 3rd gear is totally out of the question if the motor is not stroked, ALOT.
Unless your going to pull on a pure sand track. We've got an H with a 1/2 stroker and 4" pistons and can't pull 3rd gear with 14.9*38 tires in 4500lb class. Must be doing something wrong. My 2 1/2 cents worth.
Farmall Boy
09-24-2003 15:01:17
 Re: Re: Farmall H Pulling Tractor in reply to Donnie , 09-24-2003 07:32:18
I have got an M in 4500 with 14.9's and can't pull third gear!!!!!
Farmall Boy
09-23-2003 17:42:07
 Re: Re: Farmall H Pulling Tractor in reply to redcub, 09-23-2003 17:17:13
HAHA.....so far its the truth....maybe we can getta track she'll spin on soon....but this season is almost over and next season is another try...maybe we can fit an M engine in there?????/ :P
FB
09-24-2003 15:20:11
 Re: Re: Re: Re: Farmall H Pulling Tractor in reply to redcub, 09-23-2003 18:05:12
Maybe we could talk...we do have an LP manifold i have had my eyes on...and just found someone that makes aluminum deck plates....for the rest...you own ur own:p
IH H owner
09-23-2003 14:41:10
I dont know what size pistons you got in it but if you take out the sleeves(before you had it bored out)standard pistons out of a 350 engine fit in nicely and do alot for your power
FarmallXpert
09-23-2003 13:52:41
Where did you find the updraft airplane carb? What did you pay for it and does it make a difference in the horsepower and response?
TimC
09-24-2003 06:45:56
 Re: Re: Farmall H Pulling Tractor in reply to FarmallXpert, 09-23-2003 13:52:41
Cody Adgent had one for sale a few weeks back. They are easy to tune and flow very well at low and high rpms. Will feed just under 400 cubes at 35 to 4000 easy.
Chain Man
09-23-2003 12:52:36
With all due respect, I think someone has dialed your number, and you answered
TimC
09-23-2003 13:48:16
 Re: Re: Farmall H Pulling Tractor in reply to Chain Man, 09-23-2003 12:52:36
Explain..... ...
Mez25
09-23-2003 13:49:24
 Re: Re: Re: Farmall H Pulling Tractor in reply to TimC, 09-23-2003 13:48:16
You lost me, I don't understand what you were referring too...
BRAT
09-23-2003 14:33:25
 Re: Re: Re: Re: Farmall H Pulling Tractor in reply to Mez25, 09-23-2003 13:49:24
I understand!
