Aftermarket pistons and sleeves
Thin N Crispy
09-26-2003 08:13:43
I see aftermarket piston/sleeve assys for Farmall Ms up to 4.310. Will the block stand that big of a bore? How big could you go without running a sleeve?
Arky
09-26-2003 20:47:40
 Re: Aftermarket pistons and sleeves in reply to Thin N Crispy, 09-26-2003 08:13:43
How big can you go with a MH 44?
Don
09-27-2003 04:25:00
 Re: Re: Aftermarket pistons and sleeves in reply to Arky, 09-26-2003 20:47:40
A 44 is about the same, 4.875.
Arky
09-27-2003 22:29:55
 Re: Re: Re: Aftermarket pistons and sleeves in reply to Don, 09-27-2003 04:25:00
Where do you find the stuff to do that to a 44.
Bigger ++++
09-26-2003 19:13:49
Places like Lemmons are putting 5" bores in M's.
Ohio M Puller
09-26-2003 08:47:38
For what I have been told about the consistancy of the block that are out there for use pullers to build up into pulling motors, 4.25 is a very safe bore size to go with. We had three 450 blocks miked to run 4.31 and all of them would of been to thin of walled. Just my to cents, not shure on how extreme you want but look up in the archives under "FREE ADVISE". There are dirrections on how to build a good reliable motor. For what is worth if you are going to over bore a block and sleeve it just go with 4.875 pistons and get it over with.
Ohio M Puller
supermpuller4
09-26-2003 16:49:06
 Re: Re: Aftermarket pistons and sleeves in reply to Ohio M Puller, 09-26-2003 08:47:38
In Div2 pulling there a lots of M's running 4.25b and 6.50 stroke you can run water in block no problem, after that OhioMPuller knows best, I've seen his black M pull.
Ohio M Puller
09-27-2003 06:01:33
 Re: Re: Re: Aftermarket pistons and sleeves in reply to supermpuller4, 09-26-2003 16:49:06
thanks for the complement, trust me though I don't know best I just know some, thanks again. Where are you from where have you seen me pull at?
Ohio M Puller
supermpuller4
09-29-2003 15:47:03
 Re: Re: Re: Re: Aftermarket pistons and sleeves in reply to Ohio M Puller, 09-27-2003 06:01:33
I saw the black M at Paulding Ohio, I thought you put on a good show even though you got your butt reamed for trying to go around pole and not stopping at end of track. I pull a SM its got stock crank with lots of lp parts does very well in div2 and good in div3.
FB
09-26-2003 17:45:54
Division 2????? ????? ????? ....there must be some
REALLY MEAN Div.4 and 5 M's
