Farmall H drive shaft
Red
10-01-2003 13:33:53
Has anyone ever broken a drive shaft at the 4 bolt coupler going into the transmition. the way they are made there are 4 thin spots that could possible break under high torque. Has anyone ever made a hollow tube drive shaft to replace the original? Thanks, Red
Chads
10-02-2003 16:10:04
 Re: Farmall H drive shaft in reply to Red, 10-01-2003 13:33:53
I used the stock inputshaft, and built a plate that bolts onto the shaft and the coupler, Eliminated the 4 rubber washers and the tapered bolts with larger bolts that thread into the plate. That is what I did to strengthen the driveshaft. ChadS
