G PULLIN TIRES
Phillip
10-07-2003 19:28:37
Just wondered what your opinion was on putting 16.9x34's on the my JD G? THANKS!
deere puller
10-09-2003 20:37:51
 Re: G PULLIN TIRES in reply to Phillip, 10-07-2003 19:28:37
go with the 16.9x34 they will gear you down better. I would proferably go with armstrong's
2 Cylinder
10-08-2003 16:45:54
Should work just fine if you have 60hp or more. Check and make sure the places that you pull will allow you to use that size tire before you put them on. 18.4 x 34's are about an inch shorter than 16.9 x 38's, and are about 1-2" wider than a 16.9 x 38. I use 16.9 x 38's on my 70hp JD-G, but you need about 60hp to keep from powering out on the track.
