Johnney putt putt,, what can i do for pulling?
William Hickock
09-16-2001 19:55:33
hey, i have a late A john deere A. sereal number 662297. i would like to dead weight but mostley live weight it. what divisions should i pull in? what should i do to the thing? any, ANY, help would be great, i have it tore down and need to know what to do before i put it back together. thankey kindley, bill
millers pullin team
10-08-2001 20:05:53
 Re: Johnney putt putt,, what can i do for pulling? in reply to William Hickock, 09-16-2001 19:55:33
i have a 1951 "A" JD and it is a stock puller and i do real well with it and all i did was bore it 125,000s over and put dome pistons in it and shave the head 30,000s and have the cam ground and u should have ur self a good stock class puller.if u want to make it an open class puller is do what iam saving up to do is have it bord 250,000s over, have the cam ground,put propain pistons out of a "D" JD, have the shaft stroked,and put a 60 JD head on it and u will have urself a heck of an open puller. o and for the stock class try 16x9x38 tires on the back and for the open class try 15x5x38s.
p;s iam 13 years old good luck Dustin Miller. Millers Pullin Team
Leroy
09-18-2001 20:17:36
BORE it and STROKE it.
Leroy
09-18-2001 20:17:19
Dale13
09-18-2001 15:55:25
Your best bet for good info would be to do a search of archives on the John Deere discussion board.It all depends how much $$$ you want to spend.
William Cody
09-17-2001 19:03:05
Dear Wild Bill, first I'd get an electronic ignition, that's usually good for adding about 30 hp or so.
wild bill
09-17-2001 19:15:56
 Re: Re: Johnney putt putt,, what can i do for pulling? in reply to William Cody, 09-17-2001 19:03:05
how dose this gain so much horse? how is it different form the stock one?
Dale W.
09-19-2001 22:54:30
 Re: Re: Re: Johnney putt putt,, what can i do for pulling? in reply to wild bill, 09-17-2001 19:15:56
First of all, go to your money tree with all the baskets you can haul. You will spend it all, and wonder if you could spend a little more for one more boost!!!!! !!!!! Good luck, and I hope you win every time you hook. I pull stock class more for fun than anything else, but fun costs $$$$$$$$$$$$$.
