Bigger piston in an H
Chris
10-21-2003 14:47:43
I wount to know if I can drop in super H sleeves and pistions in my H useing the same connecting rods? I'm wanting to use 31/2 bore or 35/8 bore all the places i call tell me 37/16 is the biggest for the H. The Super H engine cant be that much differnt than H or can it?
ChadS
10-21-2003 22:58:00
 Re: Bigger piston in an H in reply to Chris, 10-21-2003 14:47:43
It is alot different than the H.. As the Farmalls got newer,, the ygot stronger in hp.. different heads and cams and intakes and carbs. You will have to bore the block to fit 3-5/8. but the 3-7/16 should fit in without boring. use the thin walled sleeves chads
