Block grinding Q for Chads or others
Nate
10-21-2003 19:23:12
What is done with the oil line in the block of an H when grinding for a stroked crank? Thanks.
ChadS
10-21-2003 23:04:28
 Re: Block grinding Q for Chads or others in reply to Nate, 10-21-2003 19:23:12
A small copper tube can be placed in the oil passage you could use jb weld to hold it or you could braze it. 9times out of 10 when stroking,,, you will go thru it every time. Are you using stock rods still? stock rods can be ussed up to 5-3/4 stroke. ChadS
TimC
10-21-2003 20:38:00
On some tractors you can plumb the inside after you plug the galleries that were cut into. It can also be plumbed outside the block and don't forget to supply the rockers.
