Hardening tires
Merle
10-25-2003 13:09:57
Building a tank to harden tires anybody know the temp settings and how long it takes per tire and how to check hardness all help appreciated.
Thanks
max puller
11-02-2003 08:41:41
 Re: Hardening tires in reply to Merle, 10-25-2003 13:09:57
The car racing guys use a hand held gauge, most of the racing cataloges have them. they are called a Durometer Speedway Motors.com has them for 60.00$
TimC
10-27-2003 19:25:06
I found that info at one time on the net but can't remember all the detail.
If i remember correctly, 300 degrees is to much, maybe 200 to 250 for 24 to 48 hours, maybe.
You can always play it safe and go 180 degrees or less for longer time.
A strain guage of some sort would make a hardness tester. A lever and scale (lenier distance type scale, like a ruler) pulled down with a spring loaded scale say maybe an eighth inch. Measure how much lbs of pressure is needed to press a steel pin .125 inch into the tire. Test it against an already hardned tire as a comparison.
dctom
10-27-2003 06:35:15
merle: never heard of this but would like to know what you find out please e mail me dctom42@yahoo.com thanks dctom
