1936 D Div 2 any ideas?
MDM
10-27-2003 09:12:25
I am interested in pulling div 2 with a 1936 D. any ideas on some performance gains? has anyone got any ideas on how to reinforce the hitch?
JerryB
10-28-2003 05:57:13
 Re: 1936 D Div 2 any ideas? in reply to MDM, 10-27-2003 09:12:25
Triple G Service has big high compression piston for "D"s ,I think up to 7 inch.They're phone number is 1-888-720-0830.Jerry.
Bob-Wyo
10-27-2003 20:00:11
MDM get rid of that factory hitch and build a solid one is the first step, they are like pulling with a wet noodle. You do have the fast transmission don't you?
I will email you with more from work tomarrow, no pics here at home.
Bob
MDM
10-27-2003 21:45:27
 Re: Re: 1936 D Div 2 any ideas? in reply to Bob-Wyo, 10-27-2003 20:00:11
Bob, I have counted the teeth on the sprockets yet, not sure what i have. what do you recomend? I have had the carb and mag and head redone, nothing to block and pistons yet.
bob-Wyo
10-28-2003 14:17:16
 Re: Re: Re: 1936 D Div 2 any ideas? in reply to MDM, 10-27-2003 21:45:27
MDM, you can tell the sproket size by taking out the fill plug and with a flashlite you can see what sprokets it has, if it looks like they are about to rub the cover its big (41 tooth) and there is a whole lot of dif between it and the small one, with one other size in between, hope this saves you pulling the cover.
What is the ser num? then I can tell if by chance you have the fast trans spider in it.
You are the right point now, I would really consider getting the compression up #1, and then hitch problem too, unless you are going to pull Div 1 sometime, then we can talk about a front weight bracket(a very simple one to build) as keeping the nose down is a big problem with D's Call Jerry Hindricks and ask about his HC alum pistons, I dont have his num here but it's in the Green Mag, also others in there too.
There is a couple other things you can do to, depending on the rules where you are going to pull, let me know and we'll get into that. Will Email you a pic that might encourage you some.
Best of Luck,
Bob
MDM
10-29-2003 16:34:01
 Re: Re: Re: Re: 1936 D Div 2 any ideas? in reply to bob-Wyo, 10-28-2003 14:17:16
Bob, the serial #of my D is 126500
MDM
10-27-2003 21:47:40
correction: i have not counted the sprocket teeth yet
