1468 v8
baystatebinder
03-25-2001 07:44:57
Can anyone give me an opinion on using a 1468 with a 550 ih v8 for super farm. Will it hold together and how much power will they make with a 3" turbo. Is any one pulling one and how do they do?
Thanks
jason
04-26-2003 17:55:57
 Re: 1468 v8 in reply to baystatebinder, 03-25-2001 07:44:57
I AM PULLING A 1468 WITH NO TURBO'S AND BONE STOCK ENGINE.WE FINISH TOP FIVE OR BETTER AND EVEN FINISED #1 SEVERAL TIMES.THE KEY TO THIS V8 HOOKED TO A SLED IS TO RUN LOW GEARS AND LOW TIRE PRESSURE.AS FOR THIS MOTOR NOT HOLDING UP IS A MISLED STORY,WE CURRENTLY ARE TURNING 4 GRAND AND PULLING ALL SUMMER AND FARMING EVERYDAY.A NOTE TO THE WISE,PARTS ARE ALMOST IMPOSSIBLE TO FIND.BUY SOME CHANCE YOU DECIDE TO SELL THINK TWICE THIS TRACTOR BRINGS GOOD MONEY AND A LIMITED AMOUNT WERE BUILT.GOOD LUCK
REDMAN
03-27-2003 12:30:09
Hey,baystatebinder
there used to be one in minnesota about 10 years
ago.It ran very well it was owned by about 6 different people,they all split up and parted the tractor out.I found the guy that did the work on the dv550,he said to drill the block for bigger head bolts and it will hold together good.One more thing,the dv550 came factory with a roller cam,atleast thats what i was told.
Goldsburg
03-26-2001 08:39:46
B.S.Binder -
Do not listen to the "hype" about the DV550. I would tend to bet that most of the people that put them down have never seen the inside of one! There are a few things that you will need to address to make it competitive:
1. Injection system: The two hole nozzles (as part of the MANN combustion chamber system) do not lend themselves very well to "high speed" operation. It actually was a mis-application of the MANN system, which was noted for being a relatively quiet diesel with good lugging ability. A combustion process that is keen to lugging is not a good choice for a comparatively short stroke (V8) diesel. You should look at having the nozzles or tips modified to a minimum six hole configuration and a "fast delivery" cam made for the pump. The pistons should also be changed to the typical "cone inside a Ricardo cup" type to maximize the effects of the new injection scheme.
2. Crankshaft: The crankshaft should be taken to a reputable, knowledgeable crank man in your area. He should be able to tell you some of the deficiencies of the crank. Areas I would check would be the rod journal fillets (check for cracks), also ask if he has heard of breaking the noses off of these pieces. Depending on how far you wanted to go, I would have the rod journals welded up (maybe stroked while I was at it) and then re-ground with LARGER radii in the rod fillets. A large radius would be 0.250in and should provide tremendous strength increases over the stock radii. The rods and perhaps bearings would then have to be chamfered (clearanced)to fit back onto the journal. I would take the stock rods and have them hardened to Rockwell 28 to 30 on the C scale, or preferably have custom 4340 rods made to fit the new crank (with the bigger radii). If you have rods made, you might be able to find a bearing of the proper dimensions such that they do not have to be machined. The custom rods wil also allow you to use a slightly smaller rod diameter, which would help clear any additional stroke.
3. The block: Should be line bored and line honed to ensure an absolute straight crank line. The decks should then be surfaced off of this new centerline, as well as any overboring that you have done. O-ringing of this block may be necessary, as the head stud pattern does not ensure the best clamp load distribution.
4. Call the guy that Eugene referred you to! Anyone who has built one would be able to provide you with insightfull information, provided that he is willing!
Regards,
Goldsburg
Eugene VanOpdorp
03-25-2001 09:39:29
Contact John at Caledonia Diesel Service in
Caledonia,NY. Should be able to answer any questions you have.BTW, head gaskets have been
the greater headache,don't believe he has ventilated the oil pan or block yet!
Aaron
03-25-2001 08:41:08
I don't think it'd last very long at all. They were known for dropping the bottom end. I've heard that a lot of them were made into 1466's after they blew the motor. Better off working up a 414 or 436.
Aaron
the tractor vet
03-25-2001 17:04:53
 Re: Re: 1468 v8 in reply to Aaron, 03-25-2001 08:41:08
Why waste time on a v 8 and if you are going to do it don't stop at 436 go all the way to 540 570 or 600, depending what your limit is . If you can't go over 466 i know of a good head for you.
the tractor vet
03-25-2001 17:04:18
agree with arron
03-25-2001 09:34:19
On the surface a V-8 looks better than a six. When you look strictly at the bottom end the six is stronger. As the six has only six cylinder with hopfully seven main bearings whereas the V-8 has eight cylinder vs. five main bearings. Go with the six.
MM puller
03-26-2001 14:48:46
 Re: Re: Re: 1468 v8 in reply to agree with arron, 03-25-2001 09:34:19
Hey, don't listen to them. Somebody has got to try building something different. Sure we all know that the other IH engines can really go. If you want to try the V8 do it! Prove someone wrong, it's fun! The reason I heard they got a bad rep was because they had a sort of a windage tray inside that tended after time to fall down and cover the pickup tube. And that they came from the factory timed wrong. All that could be easily fixed. I don't know if thats true but it is what I heard. They also made a DV800 that was in the big tractors. I am not trying to start fights but it is nice to see something else.
MMpuller
03-27-2001 18:16:07
 Re: Re: Re: Re: 1468 v8 in reply to MM puller, 03-26-2001 14:48:46
I believe that there is one pulling out east. Not sure though. I also think that the DV800 will bolt in. However there is a huge cosmetic difference between the two.
Lee K.
03-26-2001 19:54:30
I wonder if it is possible to stuff the big 800 cube engine in the plave of that 550 cube motor. I haven't heard all that many problems with the big motor in the 4 wheel drives. You still see many of them around. That 800 ci engine, think of the possibilities.
baystatebinder
03-26-2001 15:55:23
Thank you for your supportive comments. I love the sound of my 1568 v8 and am looking foward to making the 14 a super farm tractor. It has 120 cubic inches more than a 1466 which is 25% more so I just need to find out how to get it to hold together. I am sure someone will have the info and experience. Has anyone seen a IH v8 pull super farm?
jason
04-27-2003 19:14:19
 Re: Re: Re: Re: Re: 1468 v8 in reply to baystatebinder, 03-26-2001 15:55:23
IN OUR AREA WE PULL FARM,HOT STOCK,SUPER STOCK WE HAVE PULLED SOME HOT STOCK.I WOULD LIKE TO GET SOME INFO. FROM YOU.I ADD YOU TO MY BUDDY LIST,I AM LOOKING FOR TURBOS AND NEED SOME INFO OFF OF YOURS.IF YOU CAN LEAVE EMAIL ADRESS I CAN GIVE YOU MORE INFO AND SEND SOME PRETTY WILD PICTURES OF THE V8 STANDING UP THE FRONT WHEELS WHILE HOOKED TO A SLED. THANKS JASON ,
MIke
03-27-2001 19:03:59
Yes there is a 1468 super Farm in the state of New York. I seen it pull last summer it pulled pretty good. I believe there is a picture of it at the Empire State pullers, web site. Which can be accessed from the pulloff.
